System Information › System Requirements › Software Requirements
The following software is required only if you will be using the specified functionality:
- If you will be using Web Message Viewer (Web MV) on the CA Automation Point server machine:
- Microsoft Internet Information Server (IIS)
- Sun Microsystems Java Runtime Environment (JRE) 1.6 (CA is redistributing this component on the product DVD)
- If you will be using the Web MV GUI on a client machine:
- Microsoft Internet Explorer 7.0 or 8.0.
- If you will be using Notification Manager, one of the following is required:
- Microsoft SQL Server 2005 Service Pack 3 or higher
- Microsoft SQL Server 2008 Service Pack 1 or higher
- If you will be enabling two-way paging support in the Notification Server on the CA Automation Point server machine:
- Microsoft Internet Explorer 7.0 or 8.0 (WCTP protocol only).
- If an authenticating proxy server is used to gain access to the Internet, this proxy server must support the Basic authentication method and must support the relay of credentials when multiple proxies are used in a chain (WCTP protocol only).
- The Microsoft XML Parser (Version 6) is included and automatically installed with the CA Automation Point distribution (WCTP protocol only)
- If the WCTP protocol will be used to issue two-way page requests, the paging service must support version 1.1 of the WCTP protocol.
- If you will be using the Notification Website with the included Tomcat Java Servlet environment:
- Sun Microsystems JRE 1.6.0 (CA redistributes this component on the product DVD.)
- If you will be accessing the Notification Website on a client machine:
