The version of Apache Tomcat shipped with CA Automation Point (version 6) includes a component called the Apache Tomcat Monitor. This component runs in the system tray area and allows you to control the running status of the Apache Tomcat server. Because this Apache Tomcat Monitor program (tomcat6w.exe) requires permission to interact with system services, it cannot be executed as a standard user (a user account not in the Administrators permission group). As a result, if a standard user signs in to the CA Automation Point server machine, the Apache Tomcat Monitor displays an error message ("Unable to open the service ‘Tomcat6’") and shuts down.
To allow this program to execute properly when launched as a standard user, the privilege level of the Apache Tomcat Monitor executable must be elevated to run as an administrator. The Microsoft Windows Server 2003 operating system does not provide a compatible permission elevation technique that allows this Tomcat Monitor program to start successfully when executed from a standard user account. If you are using the Microsoft Windows Server 2008 operating system, you can use the following steps to change the properties of the Apache Tomcat Monitor executable to allow a standard user to run this program with elevated privileges.
To change user permissions
The tomcat6w Properties dialog displays.
A new tomcat6w.exe Properties dialog displays with a single tab entitled Compatibility for all users.
The Apache Tomcat Monitor executable will now execute with the required privileges when run from a standard user account.
After making this change, a standard user may need to specify the administrator password each time they sign into the Microsoft Windows Server 2008 machine to launch the Apache Tomcat Monitor application.
