Previous Topic: Apache Tomcat Monitor Fails to Start as a Standard UserNext Topic: Version of AP Help from AP Viewer May Not Correspond to Your CA Automation Point Server
No ADDRESS TNG Error Text
When the CA-AP NSM Gateway service is not running, and you execute a REXX program that calls an ADDRESS TNG command, the ADDRESS TNG command appropriately fails with error code 30 (because the CA-AP NSM Gateway service must be running to enable ADDRESS TNG commands). However, the TNG.ERROR stem variable does not contain any text to explain the scenario above.
