Previous Topic: Notification Manager Status of InitializingNext Topic: Notification Monitoring Applies to Both CA OPS/MVS and CA NSM Event Manager
Notification Manager Issues
This section discusses known issues regarding the Notification Manager.
CA Product Compatibility
Notification Manager data is stored within the CA Management Database (MDB). CA Automation Point Release 11.2 uses a new version of the MDB (version 1.5). When you install other CA products to operate against the same MDB, you must be aware of your database compatibility for all such products.
CA Automation Point automatically places an MDB compatibility tool on your system when you create a Notification Manager database. Documentation on using of this MDB compatibility tool is available at the CA technical support site, http://support.ca.com. On the site’s main page, select MDB from the Select a Product or Solution page drop-down list.
