When you enable the monitoring of notification requests from CA OPS/MVS, you automatically enable the monitoring of notification requests from CA NSM. The reverse is also true. However, if you do not want CA Automation Point to monitor one of these two sources, simply do not select any hosts for that source, and CA Automation Point will not perform any unnecessary monitoring.
