Previous Topic: Standard User and C:\Program FilesNext Topic: Upgrade JRE to Use Web MV Locally on a CA Automation Point Server
Files in Use
During installation, ensure that all files that are to be copied or deleted and their directories are not in use. If you receive a message that a copy or delete operation has not completed successfully or that files or directories are in use, shut down any open applications and if necessary, use Task Manager to close any hidden tasks that may be running. Then click Retry. If you click Ignore, Abort, or Cancel in this situation, Setup will not complete the requested operation and may result in a call to Technical Support.
A file or directory can be locked (considered in use) because of NTFS permissions on it or its directory hierarchy, or because it is being used by a process outside the control of CA Automation Point. If NTFS permissions are not the problem, then you must shut down the process or processes that are causing the locks. The following is a partial list of the processes you should consider shutting down. For some of these, you may need to use Task Manager or the Services Administrative tool to shut them down.
Important: apServerInstall.exe and apClientInstall.exe should never be stopped because they are required by the installation program.
You should be aware that the Windows kernel sometimes locks a file or directory. If you have shut down everything that Task Manager allows and the files or directories are still locked, then you need to reboot your system and retry the installation before performing any other operations.
