Previous Topic: Importing and Exporting Configuration SettingsNext Topic: Removal of NETBEUI Network Transport from PPQs
Import Sessions Utility
The new Import Sessions utility lets you move only session definitions from one machine to another, leaving the remainder of your destination machine‘s configuration unchanged. Such an operation can be useful when preparing a disaster recovery machine or when load-balancing your sessions across multiple CA Automation Point servers.
You can launch the Import Sessions program using the File, Import Sessions menu option on Configuration Manager. You can also run the Import Sessions program directly by running the program importSess.exe. For detailed information about the operation of the Import Sessions program, go to Help, Usage on the Import Sessions dialog.
