CA Automation Point now uses a single Site location on which it performs setting import and export operations. The Export and Import utility exports to and imports from a zip archive, which you can also transfer to a different CA Automation Point server and easily migrate all settings to another machine. After a successful import operation, CA Automation Point generates a consolidated report in HTML format. You can use this report to see which settings you may need to change manually.
CA Automation Point automatically creates an archive before starting an import operation. If something goes wrong during or after an import operation, you can revert to settings from a previous state using this autobackup archive.
You no longer need to stop CA Automation Point and its services to perform an export operation.
