Previous Topic: AXC0038WNext Topic: AXC0040W
AXC0039W
Session sessname will not be started because it is configured as a cut mode session which is no longer supported.
Reason:
CA Automation Point no longer supports the CUT MODE connection type.
Action:
Reconfigure the session to use TN3270 by setting a Host Name/IP and Port from the 3270 Session Settings dialog in Configuration Manager or remove the affected session.
