Previous Topic: AXC0037WNext Topic: AXC0039W
AXC0038W
Session sessname will not be started because it is configured as a hllapi session which is no longer supported.
Reason:
CA Automation Point no longer supports the HLLAPI connection type CA Automation Point.
Action:
Either reconfigure the session to use TN3270 by setting a Host Name/IP and Port from the 3270 Session Settings dialog in Configuration Manager or remove the HLLAPI session.
