This message generates any of the following:
Reason:
Notification Manager was unable to resolve the voice channel number of the specified channel.
Action:
Contact CA Technical Support.
Reason:
The rc is the return code from the ReleaseChannel request. If the return code is not zero, you may need to take action.
Action:
See the description of the RELEASECHANNEL command in the Reference Guide for more information.
Reason:
The modem port named nnnn was freed.
Action:
None.
Reason:
Notification Manager obtained channel number nnnn from the NMCALL voice group.
Action:
None.
Reason:
The modem port named nnnn was obtained.
Action:
None.
Reason:
Notification Manager obtained channel number nnnn from the NMANSWER voice group.
Action:
None.
Reason:
Notification Manager tried to use a modem, but function function-name returned result.
Action:
Reason:
Notification Manager tried to use a modem, but function function-name returned user.modem.state.
Action:
Reason:
Program-name needed a modem, but it could not obtain one.
Action:
Obtain more modems (if necessary) or use batch paging, if you are not already doing so.
Copyright © 2012 CA.
