Previous Topic: PPQ4509ENext Topic: PPQ4515E
PPQ4514E
PPQ Session is already active.
Reason:
Multiple attempts were made to connect a session to the local PPQ system.
Action:
Make sure that your TCPHOSTS files on all PPQ network-connected systems are specified once in each file. Ensure that the system names of your PPQ systems are unique. PPQs only use the first eight characters of the Windows system name, so the first eight characters must be unique within the PPQ network. If there are duplicate names, you must change the Windows system names of the ones that are duplicated. If you are unable to resolve the conflicts, locate the file ASOTRACE.LOG, then contact CA Technical Support.
