Previous Topic: AXC0980ENext Topic: AXC0982E
AXC0981E
Error opening device: devicename port: number: reason
Reason:
CA Automation Point cannot open the asynchronous communication port specified by devicename and number. The devicename is COM to identify that the device is one of the COM ports on the workstation.)
In most cases, the reason given points to an invalid setting for one of the CA Automation Point asynchronous communication parameters. However, this message can also appear if you have not loaded the driver (or have loaded the wrong driver) for the serial port expansion device.
Action:
Use the information given in reason to determine the cause of the problem and correct it. Verify that the communication port exists and is not currently in use. If you are using a serial port expansion device, verify that you loaded the proper driver.
