Specifies the number of times to retry to call a particular individual. The total number of send attempts will be one more than the CallRetry value.
Default: 4
Specifies the number of times to let the phone ring on each call attempt.
Default: 8
Specifies the number of seconds to wait between attempts to call a particular individual.
Default: 30
Specifies the number of seconds to wait for a voice channel when attempting to call a particular individual.
Default: 60
Determines whether Notification Manager is to generate debugging messages at the command prompt or the AXCREXX window and in the ASOTRACE log. Possible values are YES and NO.
Default: NO
Specifies the message to play when the phone is initially answered (before the TELL and ASK messages are played). The argument can be either a string or voice file. If the argument is a voice file, the name of the voice file must not contain any blanks and the last four characters must be .VOX.
Default: Notification Manager is calling about item number nnnn
Specifies if Notification Manager is to attempt to leave messages on answering machines. Valid values are:
Notification Manager attempts to leave a message on an answering machine as many times as possible in the allotted 90 seconds.
Notification Manager attempts to leave a message only once.
Default: YES
Specifies whether Notification Manager is to include the item number as part of the notification message. Valid values are:
Include the item number as part of the message.
Exclude the item number being played as part of the message.
For notification requests that have both TELL and ASK defined, or notification requests that reach an answering machine, the value of PassOnItemNumber is overridden and set to YES.
Default: NO
Specifies the phone number to call.
Note: This parameter must be specified at the method level. Simply specify a dummy phone number (for example, 555-1212) as the value at this level.
Specifies the name of the system that is running the notification server you want to perform the call. The sysname value can contain up to eight alphanumeric characters.
Default: The local system name
Specifies whether Notification Manager should restrict playing the notification message to just the intended contact. Valid values are:
Play a message only after the user has entered a valid entity ID and password.
Play a message without prompting the user to enter their entityID and password.
For notification requests with both the TELL and ASK parameters defined, the UsePIN value is always overridden and set to YES to insure system security, because ASK requires the user to take some type of action.
Default: YES
Specifies the Word Library to use when playing words from your TELL and ASK strings.
Default: VOXM_A
Copyright © 2011 CA.
