Define the following parameters for any method you create that invokes NMVOICE. If a parameter is marked as required, you must define it as a parameter for the method. If a parameter is not required, you do not need to define it in the database. If you do not define the parameter, the default value is to be used whenever the method is invoked.
Note: You cannot set a value for a parameter at the entity or time-block level (that is, override the default value) if you do not define the parameter at the method level.
Parameter |
Required |
CallRetry |
No |
CallRings |
No |
CallWait |
No |
ChannelWait |
No |
Debug |
No |
Greeting |
No |
LeaveMessage |
No |
PassOnItemNumber |
No |
Phone |
Yes |
System |
No |
UsePIN |
No |
Wordlib |
No |
Copyright © 2011 CA.
