The GETSYSNAMES command retrieves the system name of the local workstation and the system names of all connected notification server workstations, if any.
ADDRESS VOX "GETSYSNAMES [PREFIX(varname)] [CMDRESP(destination)]"
(Optional) Specifies the name of the REXX stem variable (other than the default name) that contains the return information for the command.
For information about changing the default variable name, see ADDRESS VOX Return Information in this chapter.
Default: VOX.GETSYSNAMES
(Optional) Directs return information to a specific destination (destination). For a list of valid destination values, see ADDRESS VOX Return Information in this chapter.
Default: REXX
Return Information:
After the GETSYSNAMES command executes, it sets the special REXX return code variable RC.
Field |
Description of Returned Information |
1 |
System name |
2 |
System type, either local (LOCAL) or connected (CONNECTED) |
3 |
Whether the engine is active (YES or NO) |
The value stored in the VOX.GETSYSNAMES.0 variable represents the total number of system names retrieved.
Example:
The following REXX code illustrates how to use the GETSYSNAMES command to retrieve the system names of all connected notification servers, and then use that information to determine whether each notification server is running and whether the connection to each notification server is active:
/* Get the system names of all connected notification servers. */
address vox 'getsysnames prefix(engines)'
/* Verify that the connected notification server is running and */
/* that the connection to it is still active. */
/* If you are running the client only, this will fail. */
/* Adjust the REXX accordingly. */
do i = 1 to vox.getsysnames.0
/* Issue a VOX command to the connected notification server */
address vox 'getgroup system('engines.i')'
/* Display the result. */
select
when RC == 0 then say 'Communication with notification server:
' engines.i 'verified.'
end
end
Copyright © 2011 CA.
