The GETSTATUS command returns the current status of a voice channel.
ADDRESS VOX "GETSTATUS CHANNELNUM(channelnum) [SYSTEM(sysname)] [PREFIX(varname)] [CMDRESP(destination)]"
A specific, physical channel number. Valid values range from 1 through the number of lines installed.
(Optional) Specifies the name of the system that is running the notification server to which you want to direct the command.
The sysname value can contain up to eight alphanumeric characters.
Default: The local system name
(Optional) Specifies the name of the REXX stem variable (other than the default name) that contains the return information for the command.
For information about changing the default variable name, see ADDRESS VOX Return Information in this chapter.
Default: VOX.GETSTATUS
(Optional) Directs return information to a specific destination (destination). For a list of valid destination values, see ADDRESS VOX Return Information in this chapter.
Default: REXX
Return Information:
After the GETSTATUS command executes, it sets the special REXX return code variable RC.
Channel Status |
Meaning |
BUSY |
Busy |
DIAL |
Dialing a telephone number |
GETDIG |
Getting digits from the voice channel's digit buffer |
IDLE |
Idle (no I/O activity on the channel) |
NOTINUSE |
Channel not in use |
PLAY |
Playing a voice message |
RECD |
Recording a voice message |
HOOK |
Setting the hook state to either on-hook or off-hook |
STOPD |
The current operation is stopped, but the channel is not idle |
WTEVT |
Waiting for a specified event to occur |
WTRNG |
Waiting for rings |
Example:
The following REXX code illustrates how to use the GETSTATUS command to determine the number of channels that are currently in use on a notification server:
/* Get a list of the local notification server's available channels. */
address vox 'getgroup group(all)'
parse var vox.getgroup.1 name interrupt numchannels
channelsingroup
channelsinuse = 0
/* Check every channel to determine in-use status of each. */
do i = 1 to numchannels
/* Get the next channel number in the group */
parse var channelsingroup channelnumber channelsingroup
/* Check channel. */
address vox 'getstatus channelnum('channelnumber') prefix(status)'
/* Maintain a count of the number of in-use channels. */
if status <> "NOTINUSE" then channelsinuse = channelsinuse + 1
end
Copyright © 2011 CA.
