ADDRESS VOX Commands › Notification Manager Database Maintenance Commands › NMIMPORT Command
NMIMPORT Command
The NMIMPORT command imports an exported copy of a Notification Manager database.
Important: This command destroys all existing data in the database before importing new data.
ADDRESS VOX "NMIMPORT PATH(path)"
- PATH
Specifies the name of the path from which the exported database is retrieved.
Return Information:
After the NMIMPORT command executes, it sets the special REXX return code variable RC.
- If the command executes successfully, the RC variable contains a value of zero.
- If the command does not execute successfully, the RC variable contains a non-zero value. Additionally, the VOX.ERROR variable contains the complete VOX error message, which includes the four-digit return code and complete error message text.
Usage Notes:
- It is important that the database is not being used when issuing the NMIMPORT command. To guarantee this, shut down the CA-AP NM Gateway Server service before running the NMIMPORT command.
- CA does not support importing a Notification Manager database that has been exported from a newer release of CA Automation Point into an older release of CA Automation Point.
Example:
The following example imports a copy of an exported database that resides in the G:\TEMP_EXP directory:
ADDRESS VOX "NMIMPORT PATH(G:\TEMP_EXP)"
Copyright © 2011 CA.
