This command retrieves the ask text and tell text for an item from the Notification Manager database.
ADDRESS VOX "NMIGETITEM ITEM(item) [CMDRESP(destination)] [PREFIX(varname)]"
Specifies the item number.
(Optional) Directs return information, if any, to a specific destination. For a list of valid destination values, see ADDRESS VOX Return Information in this chapter.
Default: REXX
(Optional) Specifies the name of the REXX stem variable (other than the default name) that contains the return information for the command.
For information about changing the default variable name, see ADDRESS VOX Return Information in this chapter.
Default: VOX.NMIGETITEM
Return Information:
After the NMIGETITEM command executes, it sets the special REXX return code variable RC.
Example:
The following example retrieves the values of the TELL and ASK parameters for item 1234:
ADDRESS VOX "NMIGETITEM ITEM(1234)" PARSE VAR vox.nmigetitem y 2 tellmsg (y) askmsgs (y). Say "The TELL text for this item is" tellmsg Say "The ASK text for this item is" askmsgs
Copyright © 2011 CA.
