This command sets or retrieves the answer for an item in the Notification Manager database.
ADDRESS VOX "NMIANSWER ITEM(item) ANSWER(ansnum)"
Specifies the item number.
Specifies a number that is the answer to the item, from 0 to 9. To set the answer for the item, specify a value from 1 to 9. To retrieve the answer for the item, specify the value 0. The answer for the problem is returned in the return code. If the problem has not been answered, the answer is 0. If the problem has already been answered, the new answer is rejected and the value of the existing answer is returned.
Return Information:
After the NMIANSWER command executes, it sets the special REXX return code variable RC.
Example:
The following example answers item 1234, and then checks to see whether it receives the same answer on its second call. (If the SAY statement runs, there is a problem.)
ADDRESS VOX "NMIANSWER ITEM(1234) ANSWER(5)" answer = rc ADDRESS VOX "NMIANSWER ITEM(1234) ANSWER(0)" IF answer<>rc THEN SAY "Expected" answer "received"rc
Copyright © 2011 CA.
