This command adds an entity to the list of entities that are allowed to call in on an item.
ADDRESS VOX "NMIADDCALLER ENTITY(key) ITEM(item)"
Specifies the key of the entity.
Specifies the item number.
Return Information:
After the NMIADDCALLER command executes, it sets the special REXX return code variable RC.
Example:
The following example tells the entity with key 100001000 to call in on item 1234:
ADDRESS VOX "NmiAddCaller ENTITY(100001000) ITEM(1234)"
Copyright © 2011 CA.
