The LIST command lists information about one or more queues residing on the local or remote workstation, or both. The optional QUEUE and SCOPE operands allow you to specify search criteria to target specific queues. This command is useful for troubleshooting TCP/IP problems.
Each line of information that the LIST command returns represents one queue. Each field in a line contains a specific type of information about the queue, as follows:
Field |
Description |
1 |
The name of the queue |
2 |
The number of items in the queue |
3 |
The maximum number of items allowed in the queue |
4 |
The maximum allowed length of each item |
5 |
The lock nesting counter |
6 |
The name of the transport where the queue was found |
7 |
The scope of the queue (local, remote, or shared) |
8 |
The name of the transport the queue uses |
9 |
The system name of the creator of the queue |
ADDRESS PPQ 'LIST [CMDRESP(destination)]
[PREFIX(newvarname)]
[QUEUE(qname)]
[SCOPE(ALL|LOCAL|REMOTE)]
[TRANSPORT(network-transport-name)]'
(Optional) Directs return information, if any, to a specific destination. For a list of valid destination values, see the section Change the Default Return Destination with CMDRESP.
Default: REXX
(Optional) Directs return information to a stem variable name (newvarname) other than the default. For more information, see ADDRESS PPQ Return Information.
Note: The PREFIX operand is only valid if REXX is the destination of the return information.
Default: PPQ.LIST
(Optional) Specifies the 1- to 16-character name of the queue (qname). The queue name can contain alphanumeric characters and any of these special characters: ! @ # $ _
The queue name cannot contain blanks.
Note: Wildcard characters are not valid in this case.
(Optional) Specifies queues on the local or remote workstation, as follows:
Lists queues residing on the local workstation and queues on remote workstations that REXX programs on the local workstation have accessed.
Lists only those queues residing on the local workstation.
Lists only those queues residing on remote workstations that REXX programs on the local workstation have accessed.
Default: ALL
(Optional) Specifies a valid transport.
The network-transport-name is the network transport specified on the TRANSPORT() startup initialization parameter.
Valid network transport names are:
The network transport is TCP/IP.
When TRANSPORT(PPQTCP) is specified, the LIST command displays the current state of each TCP/IP connection to the remote hosts listed under TCP/IP Host Names in the Configuration Manager Program-to-Program Queues dialog.
'LIST TRANSPORT(PPQTCP)' displays one of the following forms of output:
If the local machine is configured only with IPv4 under TCP/IP:
Session nnnnnnn: IP: iphost1 State: host1state Host 'host1' Session nnnnnnn: IP: iphost2 State: host2state Host 'host2'
If the local machine is configured to support both IPv4 and IPv6 under TCP/IP:
Session nnnnnnn: State: host1state IP: iphost1 Host 'host1' Session nnnnnnn: State: host2state IP: iphost2 Host 'host2'
nnnnnnn -- Specifies the internal session identifier
iphostn- -- Specifies the IPv4 or IPv6 address for the host named hostn; an IPv6 address will be enclosed in square brackets
hostnstate -- Specifies the state of the session that is connected to the host named hostn. Values are UP, DOWN, STARTING, LISTEN, BROKEN, and UNKNOWN.
Notes:
Copyright © 2011 CA.
