The DEBUG command controls debugging trace output. You can prevent messages below a specified severity level from being traced, and you can specify what types of messages that you want to trace. Like the TRANSTATUS command, the DEBUG command is a diagnostic tool.
ADDRESS PPQ 'DEBUG [CATEGORY(hexbitfield)]
[CMDRESP (destination)]
[SEVERITY(severitylevel)] '
(Optional) Specifies a mask for the category of message to be traced. Specify the hexbitfield value as a 32-bit hexadecimal string. Each bit position containing a 1 allows the trace utility (ASOTRACE.exe) to trace the corresponding message category.
Default: FFFFFFFF
This parameter specifies the bit assignments are as follows:
General Hex Code |
Trace Type |
FFFFFFFF |
All |
00000001 |
Startup |
00000002 |
Initialization and termination |
00000004 |
Manager thread |
00000008 |
API entry point |
00000010 |
Status |
Hex Code |
Trace Type |
00000020 |
Control block |
00000040 |
Packet |
00000080 |
Memory allocation |
00000100 |
High volume routine |
Application Hex Code |
Trace Type |
00100000 |
Utility routine |
00200000 |
PPQ |
00800000 |
VOX |
01000000 |
OCF |
00200000 |
GLV |
(Optional) Directs return information, if any, to a specific destination. For a list of valid destination values, see the section Change the Default Return Destination with CMDRESP.
Default: REXX
(Optional) Prevents tracing of messages with severity levels below the level specified for severitylevel. Valid severity levels are:
Error
Warning
Informational
4-8
Debug levels
Note: CA Technical Support specifies the appropriate debug trace level when necessary.
Default: 1
Copyright © 2011 CA.
