Specifies the number of seconds that the e-mail request is to delay the processing of subsequent actions in the call tree.
Default: 60
Specifies the e-mail recipient names that are to receive a carbon copy of this e-mail.
Determines whether Notification Manager is to generate debugging messages at the command prompt or the AXCREXX window and in the ASOTRACE log.
Default: NO
Specifies the number of times the e-mail request is to be retried if it does not go through.
Default: 4
Specifies the number of seconds that Notification Manager is to wait before trying to send an e-mail request again.
Default: 60
Specifies the maximum length of an e-mail recipient list (either the TO or CC list), including the separators.
Default: 1000
Specifies the maximum length of a message that the e-mail system supports.
Default: 30000
Specifies the maximum length of a Signature text string (Mail ID).
Default: 40
Specifies the maximum length of a Subject text string.
Default: 240
Specifies the number of seconds that Notification Manager allows the person who received the e-mail to call in and handle the item before it executes the FAILURE command.
Database Default: 300
Internal Default: 900
Determines whether the pager to be contacted is numeric (YES) or not (NO).
Default: NO
Specifies the password for the pager service. Specify the password only if required by the paging service.
Default: No password
Specifies the phone number that is to issue a page to the pager. Everything except the numeric digits are omitted from this phone number.
Note: Some pager companies require the phone number to be in a special format (for example, not entering an area code or dialing 1 before an 800 number).
Specifies the number of numeric digits that a properly specified phone number should have.
Notification Manager uses this parameter to generate warning messages during execution. If you do not want to see warning messages or if the number of digits that the pager service requires is variable, specify 0 for this parameter.
Specifies the PIN of the pager.
Specifies the optional user-defined text that identifies or tracks the e-mail message.
Default: Notification Manager Automated Response
Specifies the Subject line of the generated e-mail message.
Internal Default: Notification Manager item number xxxx
Specifies the name of the system that is to handle all notification server requests.
Internal Default: The local system name
Determines whether the TELL text from the NMFIND command is to be written to the e-mail verbatim. Values are:
The TELL text is written to the e-mail verbatim.
Allows Notification Manager to add a call-in number and item number to the TELL text.
Specifies the e-mail recipient names that are to receive this message. If more than one name is specified, these names must be separated by a semicolon (;).
Specifies the formula, or set of rules, the pager service is to follow to combine the Phone, PagerPW, and PIN parameters, generating an e-mail ID.
You can specify any valid REXX expression in this parameter. To use a parameter value in the expression, specify the name of the parameter, not its value. Use an exclamation point (!) for the pipe symbol (|), and use a single quote (') for any quotes.
For example, if the Skytel service required you to take the PIN and then add the string "@skytel.com", the formula would be:
PIN!!'@skytel.com'
