Previous Topic: NMMAILPG Parameter Descriptions
Next Topic: NMNETSND Parameter Descriptions
NMNETSND Method
The NMNETSND program provides a means for NMFIND to contact people via the local area network (LAN) by issuing a NET SEND command. A message is sent to a specified computer name or a domain.
Specify the following items when defining a method that uses NMNETSND:
Define the following parameters for any method that uses NMNETSND as its invocation string. If a parameter is marked as required, you must define it as a parameter for the method. If a parameter is not required, you do not need to define it in the database. If you do not define the parameter, the default value is used whenever the method is invoked.
Note: If you do not define the parameter at the method level, you cannot set a value for a parameter at the entity or time-block level (that is, override the default value).
Parameter
Required
AllUsers
No
Answerwait
No
Debug
No
Domain
No
Greeting
No
MaxMsgLen
No
Name
Yes
NMFindWait
No
Retry
No
RetryWait
No
TellExact
No
