The SCRIPT command invokes a CA Automation Point script from a REXX program. The script executes immediately.
"SCRIPT scriptname SESSION(sessname)"
Specifies the file name of the script to execute.
Specifies the name (sessname) of the target session in which CA Automation Point should activate the script.
Example:
The SCRIPT command shown below invokes a script called PAUSE.SCR, which restores the MCS console for session S028 for manual use:
"SCRIPT PAUSE.SCR SESSION(S028)"
