Previous Topic: Commands for REXX-related Operations
Next Topic: SCRIPT Command
REXX Command
The REXX command queues a REXX program for processing by CA Automation Point. You can also use the REXX command within a REXX program to start another, independent REXX program.
"REXX 'execname args'"
execname
Specifies the name of the REXX program for CA Automation Point to execute.
args
Specifies the calling arguments for the specified REXX program.
Note: The length of the argument list (REXX program name and its arguments) is limited to 505 characters. An incoming argument list longer than 505 characters is truncated.
Example:
The following command invokes a REXX program called XCDEMO with the argument GETMSG:
"REXX 'XCDEMO GETMSG'"
