Previous Topic: MAP Parameter
Next Topic: 3270_KEY Parameter
Scan Code Parameters
Scan code parameters define operations in scan code files. For details about customizing these types of files, see the appendix on customizing special CA Automation Point files in the Administrator Guide.
The following are the CA Automation Point parameters you need to define when specifying your scan code parameter file.
3270_KEY
Specifies the operation that is being defined (for example, A, PF1, and so on).
3270_SCAN
Specifies the terminal-specific scan code for the operation.
When defining operations in a scan code file, follow these rules:
