Previous Topic: SCAN Parameter
Next Topic: Scan Code Parameters
MAP Parameter
The MAP parameter specifies the type of window on which this operation applies.
This parameter has the following format:
MAP=sessiontype
sessiontype
Valid values are:
AUTOMATE
Specifies that the key applies only in asynchronous session windows, CA Automation Point function windows, and CA Automation Point menus and dialogs.
TERMINAL
Specifies that the key applies only in CA Automation Point 3270 or 5250 terminal emulator session windows.
(AUTOMATE, TERMINAL)
Specifies that the key applies in both types of session windows.
Default: (AUTOMATE,TERMINAL)
