The UNIWTO command sends the supplied message to the CA NSM Event Manager component on the specified host.
ADDRESS TNG "UNIWTO HOST(HostName|*) MESSAGE(MessageString)
[ORIGHOST(OriginatingHostName)]
[SEVERITY(E|F|I||S|W)]"
Specifies the TCP/IP host name (HostName) to which the event is to be sent or * for all host names specified for message forwarding in the Configuration Manager GUI.
Specifies the message (MessageString) to be sent to CA NSM.
(Optional) Specifies the name of the host (OriginatingHostName) on which the event originated.
Default: The host name of the CA Automation Point machine.
(Optional) Specifies the CA NSM severity value. Values are:
E - Error
F - Fatal
I - Information
S - Success
W - Warning
Default: I
