The UNICMD command tells the CA NSM Event Manager component, which resides on the specified host, to execute the supplied command.
ADDRESS TNG "UNICMD HOST(HostName) COMMAND(CommandString)"
Specifies the TCP/IP host name (HostName) to which the event is to be sent
Specifies the command (CommandString) to be executed by CA NSM
