The STARTREXX command executes another REXX program.
Note: You can also use this command to start any executable program on a local system.
ADDRESS VOX "STARTREXX PROGRAM(progname[arguments])"
Specifies the name of the REXX program that you want to execute and the arguments to pass to the program, if any.
Return Information:
After the STARTREXX command executes, it sets the special REXX return code variable RC.
Example:
The following REXX code illustrates how to use the STARTREXX command in a program that processes incoming calls destined for the help desk. When CA Automation Point receives a call, the HDCTRL.CMD program starts a program named HELPDESK.cmd to service the call automatically.
/* HDCTRL.CMD */ signal on halt Name DoExit do forever /* Wait forever for an incoming call and any channel within */ /* the HELPDESK group. */ address vox answer group(helpdesk) hookstate(onhook) prefix(handle)' if RC == 0 then do /* Call answered. Start the HELPDESK.CMD */ /* program to service the call. */ address vox 'startrexx program(helpdesk.cmd 'handle')' end end DoExit: /*Exit from the command shell so that CA Automation Point can "cleanup."*/ '@exit' end
