The SLEEP command causes the issuing REXX EXEC to enter a system sleep state for the given amount of time.
ADDRESS VOX "SLEEP SECONDS(seconds) MILLISECONDS(milliseconds)"
Specifies the number of seconds to sleep.
Specifies the number of milliseconds to sleep.
Return Information:
After the SLEEP command executes, it sets the special REXX return code variable RC.
Example:
The following example of the SLEEP command gets a channel, calls a number, and-when the connection is made-sleeps for two seconds:
address vox 'getchannel channelnum(1) prefix(handle)'
address vox 'call channel ('handle')tonestring('phonenumber')'
if vox.call.1 = 'PAMD' then do
/* Because some automated attendants have a long salutation */
/* wait for 2 seconds before sending any tones. */
address vox 'sleep seconds(2)'
/* Have the automated attendant transfer */
/* your call to the desired extension. */
address vox 'sendtones channel('handle') tonestring('extension')'
end
address vox 'releasechannel channel('handle')'
