The LISTFORTO command lists all the time blocks that forward to a given entity (regardless of the time and date). The list is actually a tree and can contain any level of nesting.
ADDRESS VOX "LISTFORTO NAME(name)|KEY(key) [CMDRESP(destination)] [PREFIX(varname)]"
Specifies the name of the entity for which the tree is to be created.
Specifies the key of the entity for which a tree is to be created.
(Optional) Directs return information, if any, to a specific destination. For a list of valid destination values, see the section ADDRESS VOX Return Information.
Default: REXX
(Optional) Specifies the name of the REXX stem variable (other than the default name) that contains the return information for the command.
For information about changing the default variable name, see the section ADDRESS VOX Return Information.
Default: VOX.LISTFORTO
Return Information:
After LISTFORTO executes, it sets the special REXX return code variable RC.
Usage Note:
For further details, see the sample REXX program lstforto.rex, located in the CA Automation Point installation directory \sample\nm.
Example:
The following example checks the tree for Fran Smith at 10:00 a.m. on October 11:
ADDRESS VOX "LISTFORTO NAME(Fran Smith)"
