Previous Topic: LISTENTITY Command
Next Topic: LISTFORTO Command
LISTFIND Command
The LISTFIND command lists the time blocks that are active for one or more entities at a given date and time. The list is actually a tree and can contain any level of nesting.
ADDRESS VOX "LISTFIND NAME(name)|KEY(key) DOW(dow)|DATE(mm/dd) TIME(hh:mm)
   [CMDRESP(destination)]
   [MTUP (A|profile)]
   [PREFIX(varname)]"
NAME
Specifies the name of the entity for which a find tree is to be created.
KEY
Specifies the key of the entity for which a find tree is to be created.
DOW
Specifies the day for which you want to search.
Days are specified as the first three characters of their English names. You can specify only one day. If you specify this operand, you cannot specify the DATE operand.
DATE
Specifies the date (no year is specified) for which you want to search.
If you specify this operand, you cannot specify the DOW operand.
TIME
Specifies, in military time format (00:00 to 23:59), the time for which you want to search.
CMDRESP
(Optional) Directs return information, if any, to a specific destination. For a list of valid destination values, see the section ADDRESS VOX Return Information.
Default: REXX
MTUP
(Optional) Use the Methods to Use Profile (MTUP) operand to specify which methods are attempted for a particular instance of an NMFIND notification request. The method type code for each method is defined in the Notification Manager database under the TYP parameter for the method. Before attempting to notify a contact using a scheduled method, Notification Manager compares the value its method type code with the profile specified on the MTUP operand. If the method type code is not part of the MTUP profile, notification is not attempted, and the next scheduled method is compared against the MTUP profile. If the method type code is part of the MTUP profile, then the notification is attempted using that method.
The values for this operand are:
profile
Any combination of method type codes B through W.
A
All method types specified for all active schedules. No comparisons are made, and all methods are attempted.
Default: A
PREFIX
(Optional) Specifies the name of the REXX stem variable (other than the default name) that contains the return information for the command.
For information about changing the default variable name, see the section ADDRESS VOX Return Information.
Default: VOX.LISTFIND
Return Information:
After LISTFIND executes, it sets the special REXX return code variable RC.
Usage Note:
For further details, refer to the sample REXX programs listfind.rex and listmtup.rex located in the CA Automation Point installation directory \sample\nm.
Example:
The following example checks the tree for Fran Smith at 10:00 a.m. on October 11:
ADDRESS VOX "LISTFIND NAME(Fran Smith) TIME(10:00) DATE(10/11)"
