Obtains a list of HTTP methods that can be issued against this URI.
None
None
Supply a user ID and password in the HTTP Basic Authentication format. The user ID must be an NM Login. The user also must have either the Answer All Notifications privilege or an associated contact for that user must have been notified as part of the notification.
Successful result = 200 = Ok
A result of 404 (Not Found) is returned when the associated notification did not ask a question and thus cannot have an answer.
List of allowed methods. This header contains OPTIONS, GET, HEAD, and PUT when the user is authorized to answer the notification and it was not answered yet.
AllowedMethods in schema AllowedMethods.xsd
This reply contains the same methods as listed in the HTTP Allow header.
