Previous Topic: URI https://localhost:8443/apwebsvc/notifications/<notificationId>/answer
Next Topic: OPTIONS notifications/<notificationId>/answer
GET notifications/<notificationId>/answer
Get the properties of the answer to a notification.
Query Options
None
Request Document
None
HTTP Request Headers
Authorization
Supply a user ID and password in the HTTP Basic Authentication format. The user ID must be an NM Login. The user also must have the Answer All Notifications privilege or an associated contact for that user must have been notified as part of the notification.
HTTP Response Headers
Status
Successful result = 200 = Ok
A result of 404 (Not Found) is returned when the associated notification did not ask a question and thus cannot have an answer.
Successful Reply Document
NotificationAnswer in schema NotificationAnswer.xsd
The reply contains the numeric choice that was made to answer the notification. The valid numeric answers range from 1 to 9. When the notification has not yet been answered, the numeric answer 0 is returned. The AnswerText associated with the numeric choice is also returned.
