The following key operations control functions specific to CA Automation Point only:
Operation |
What It Does |
Enhanced 101-keys Mapped to Operation |
CONNECT |
Issues a connect request for the session. For more information, see the discussion of SESSCNTL CONNECTION in the Command and Keyword Reference Guide. |
CMD_HOST |
Lets you send console commands to specific terminal emulator sessions. (This operation does not work from a REXX program.) |
User-definable |
DISCONNECT |
Issues a disconnect request for the session. For more information, see the discussion of SESSCNTL CONNECTION in the Command and Keyword Reference Guide. |
EXECUTE |
Executes a script from the current session window. (This operation does not work from a REXX program.) |
User-definable |
FONT_LARGER |
Selects the next larger font in the current window and increases the window size proportionately |
Ctrl+ |
FONT_SMALLER |
Selects the next smaller font in the current window and decreases the window size proportionately |
Ctrl+
NEXT |
Switches to the next session controlled by CA Automation Point. (This operation does not work from a REXX program; it only works in the red command area.) |
Alt+N
PAUSE |
Tells CA Automation Point to pause automation by releasing control of automated sessions. (This operation does not work from a REXX program.) |
User-definable |
SCREEN_LAYOUTS |
Opens the Layouts dialog. For more details, see the section Layouts |
SCREEN_LOAD |
Loads the current active layout (if it exists). For more information, see the section Active Layout. |
SCREEN_SAVE |
Saves the current layout under last active layout (if it is set). For more information, see the section Active Layout. |
QUIT |
Closes the specified window (but does not halt automation of the session in that window) |
User-definable
WIN_NEXT |
Jumps to the next CA Automation Point window |
Alt+J |
