The following table displays the keys mapped to terminal operations:
Operation |
What It Does |
Enhanced 101-keys Mapped to Operation |
0 to 9 |
Types the indicated number (from 0 to 9) on the host screen |
0 to 9 |
A to Z |
Types the indicated uppercase letter (from A to Z) on the host screen |
A to Z |
a to z |
Types the indicated lowercase character (from a to z) on the host screen |
a to z |
ATTN |
Issues an attention to the terminal |
Shift+Esc |
BACK_QUOTE |
Types an accent grave (backward quote) character on the host screen |
BACK_SLASH |
Types a back slash (\) on the host screen |
BACK_SPACE |
For a terminal emulator window, moves the cursor one space left |
Back |
BACK_TAB |
Moves the cursor backwards one position |
Shift+Tab |
CLEAR |
Clears the current screen of text |
Keypad+Minus |
COMMA |
Types a comma on the host screen |
CURSOR_BLINK |
Turns blinking cursor on or off |
User-definable |
CURSOR_SEL |
Changes the cursor from a block to an underline character or, conversely, from an underline character to a block |
Scroll Lock |
DEV_CNCL |
Issues a DEV_CNCL instruction |
User-definable |
DOUBLE_QUOTE |
Types double quotation marks on the host screen |
DOWN |
Moves cursor down one line |
DUP |
Issues a DUP instruction |
101E+Shift+Insert |
END |
Moves cursor to the bottom left corner of the screen |
End |
ENTER |
Issues a carriage return |
Enter |
EQUAL |
Types an equal sign on the host screen |
ERASE_EOF |
Erases all characters immediately following the cursor on this screen field |
101E+End |
ERASE_INPUT |
Erases all unprotected fields on the host screen |
101E+Alt+End |
FAST_LEFT |
Moves cursor two spaces to the left |
101E+Alt+Left |
FAST_RIGHT |
Moves cursor two spaces to the right |
101E+Alt+Right |
FIELD_EXIT |
Issues "Field Exit" to the iSeries console (5250 only) |
Alt+E |
FM |
Issues a field mark instruction |
101E+Shift+Home |
HAT |
Types the not equal character (¬ on the host screen Note: Your workstation screen displays the ^ character. |
Shift+6 |
HOME |
Moves cursor to the first unprotected field on the host screen |
Home |
IDENT |
Issues an IDENT instruction |
User-definable |
INS |
Turns insert mode on |
Insert |
LEFT |
Moves cursor left one character position |
LEFT_BRACKET |
Types the vertical bar character (|) on the host screen Note: Your workstation screen displays the [ character. |
LEFT_PAREN |
Types a left parenthesis on the host screen |
LINE_INS |
Issues a Line Insert instruction |
User-definable |
LINE_DEL |
Issues a Line Delete instruction |
User-definable |
MODE_SEL |
Switches between a hardware console and software console session on an CA Automation Point terminal emulator |
User-definable |
NEWLINE |
Line feed; moves cursor to the next line (3270 only) |
Ctrl+Enter |
PA1 |
Invokes the command assigned to the PA1 key |
101E+Page Up |
PA2 |
Invokes the command assigned to the PA2 key |
101E+Page Down |
PA3 |
Invokes the command assigned to the PA3 key |
101E+Shift+Page Down |
PF1 to PF9 |
Invokes the command assigned to the indicated PF key |
F1 to F9 |
PF10 |
Invokes the command assigned to the PF10 key |
F10 |
PF11 |
Invokes the command assigned to the PF11 key |
F11
PF12 |
Invokes the command assigned to the PF12 key |
F12 |
PF13 to PF24 |
Shift+F1 to Shift+F12 |
PF26 to PF36 |
User-definable |
Pgdn |
Moves the cursor down one full page |
Page Down |
PGDN |
Issues a Page Down to the iSeries cosole (5250 only) |
PgDn |
PgUp |
Moves the cursor up one full page |
Page Up |
PGUP |
Issues a Page Up to the iSeries cosole (5250 only) |
PgUp |
POWER_RESET |
Sends a reset-terminal instruction to the controller |
Ctrl+Page Down |
RESET |
Issues a RESET instruction |
Esc |
RIGHT |
Moves cursor right one character position |
RIGHT_BRACKET |
Types a cent-sign character (¢) on the host screen Note: Your workstation screen displays the ] character. |
RIGHT_PAREN |
Types a right parenthesis on the host screen |
SINGLE_QUOTE |
Types a single quotation mark character (') on the host screen |
SPACE |
Types a blank space on the host screen |
Space bar |
SPLIT_BAR |
Types a splitbar character (|) on the host screen |
START |
Starts up a mainframe system connected to the workstation through a terminal emulator |
User-definable |
STOP |
Shuts down a mainframe system connected to the workstation through a terminal emulator |
User-definable |
SYS_REQ |
Issues a SYS_REQ instruction |
Alt+F1 |
TAB |
Moves cursor forward one tab position |
Tab |
TEST |
Issues a TEST instruction |
Alt+F8 |
UNDER |
Types the underline character on the host screen |
_ |
UP |
Moves the cursor up one line |
Types an exclamation point on the host screen |
Types a pound sign on the host screen |
Types a dollar sign on the host screen |
Types a percent sign on the host screen |
Types an ampersand on the host screen |
Types an asterisk on the host screen |
Types a plus sign on the host screen |
Types a minus sign on the host screen |
Types a period on the host screen |
Types a slash on the host screen |
Types a colon on the host screen |
Types a semicolon on the host screen |
Types a question mark on the host screen |
Types an at sign on the host screen |
Types a left brace on the host screen |
Types a right brace on the host screen |
Types a vertical bar on the host screen |
Types a tilde on the host screen |
3270_ASSIGN |
Issues an ASSIGN instruction |
User-definable |
3270_CANCEL |
Issues a CANCEL instruction |
User-definable |
3270_IRPT |
Issues an IRPT instruction |
User-definable |
3270_ISTEP |
Issues an ISTEP instruction |
User-definable |
3270_PLAY |
Issues a PLAY instruction |
User-definable |
3270_RECORD |
Issues a RECORD instruction |
User-definable |
3270_RESTART |
Issues a RESTART instruction |
User-definable |
3270_RULE |
Issues a RULE instruction |
User-definable |
3270_SETUP |
Issues a SETUP instruction |
User-definable |
3270_SVPCE |
Issues an SVPCE instruction |
User-definable |
3270_SWAP |
Issues a SWAP instruction |
User-definable |
3270_TOD |
Issues a TOD instruction |
User-definable |
3270_1 to 3270_25 |
User-defined |
User-definable |
6530_ROLL_UP |
Issues a Roll Up instruction (6530 only) |
User-definable |
6530_SROLL-UP |
Issues a Shifted Roll Up instruction (6530 only) |
User-definable |
6530_ROLL_DOWN |
Issues a Roll Down instruction (6530 only) |
User-definable |
6530_SROLL_DOWN |
Issues a Shifted Roll Down instruction (6530 only) |
User-definable |
6530_NEXT_PAGE |
Issues a Next Page instruction (6530 only) |
User-definable |
6530_SNEXT_PAGE |
Issues a Shifted Next Page instruction (6530 only) |
User-definable |
6530_PREV_PAGE |
Issues a Prev Page instruction (6530 only) |
User-definable |
6530_SPREV_PAGE |
Issues a Shifted Prev Page instruction (6530 only) |
User-definable |
6530_RETURN |
Issues a Return instruction (6530 only) |
User-definable |
6530_SRETURN |
Issues a Shifted Return instruction (6530 only) |
User-definable |
