Use the manual session to manage AS/400 systems independently from the automation sessions. To avoid conflicting with REXX programs, enter OS/400 full-screen commands from the manual session only. Immediately after you log in, map the keyboard by entering the following command:
CALL KBD3270
A suggested session name for the manual AS/400 session is AS400MAN.
Your installation may have defined multiple manual sessions for multiple systems or none at all.
