AS/400 Manager provides several AS/400 Manager application commands for your use. The commands are:
Suspends control of a system
Resumes control of a system
Displays system status in the AP Msg window
Displays configuration information in the AP Msg window
Sends an OS/400 command to a system
Note: These application commands require that automation be active on the rules session. AS/400 Manager application commands do not function when CA Automation Point is globally paused or when automation is paused in the rules session.
