To manually resume control of an AS/400 system, issue this command in the command area:
RESUME sysname
Specifies an AS/400 system, tag, or group name to be resumed.
Note: After an AS/400 system fails, use the RESUME command to reestablish control of that AS/400 system. The actual effect of the RESUME command is to set the status of the relevant system (or systems) to RSTART. This causes screen-position checking (and, where necessary, error recovery) procedures to be invoked the next time communication to the system is needed.
