Important! Extending the directory schema is an advanced and complex operation with far-reaching implications. Different directory products have different syntax and methods for modifying and extending the schema. Before you do this, be sure to consult your directory's documentation.
CA Automation Point provides three sample files to help you extend the directory schema. They are:
If you are using the CA Directory product, you can use this file as a sample eTrust .dxc configuration script file.
If you are using the Microsoft Corporation Active Directory product, you can use this file as a sample LDAP Data Interchange Format (LDIF) script file. Alternatively, you can use the Active Directory Schema MMC Snap-in to extend the schema.
If you are using the Apache Directory server product, you can use this file as a sample LDAP Data Interchange Format (LDIF) script file.
You can find these samples in the directory installDir\SAMPLE\NM\WebSecurity.
