The following table shows the objectClass definitions used for the Advanced Permissions.
ObjectClass and OID |
Description and Attributes |
Structure |
apnmLoginRights apnmoid.2.1 (1.3.6.1.4.1.791.2.10.5.3.2.1) |
Defines entries representing the NM login user. Contains attributes that specify the NM authorization permissions Mandatory attributes: commonName Optional attributes: nmLoginName Multiple values may be set for any of these attributes. |
This is a structural object subclassed from the top. An apnmLoginRights entry may be placed under an organizationalUnit entry in the directory. For more information on the directory hierarchy, see the section How You Extend the Schema. |
apnmLoginPerson apnmoid.2.2 (1.3.6.1.4.1.791.2.10.5.3.2.2) |
Defines entries representing NM login user. Use to construct the NM login team branch in your directory. Mandatory attributes: commonName Multiple values may be set for either of these attributes. |
This is a structural object subclassed from top. An apnmLoginPerson entry may be placed under an organizationalUnit entry in the directory. For more information on the directory hierarchy, see the section How You Extend the Schema. |
apnmContactPerson apnmoid.2.3 (1.3.6.1.4.1.791.2.10.5.3.2.3) |
Defines entries representing the NM contact user. Use to construct the NM contact team branch in your DIT. Mandatory attributes: commonName Multiple values may be set for either of these attributes. |
This is a structural object subclassed from top. An apnmContactPerson entry may be placed under an organizationalUnit entry in the directory. For more information on the directory hierarchy, see the section How You Extend the Schema. |
Note: A special "everyone" contact name can be used for attributes that specify permissions for an NM contact user. These attributes include nmNotifyContacts, nmReadContacts, and nmUpdateContacts. This special value is recognized internally by CA Automation Point, and can be used to indicate the broad permissions a login user may have.
