To configure two-way paging
The 2-Way Paging Setup dialog displays.
This enables two-way paging inside the Notification Server, and allows you to start adding symbolic names of paging service providers.
For example, if you want to add a new paging service provider, and this paging service supports the SNPP communications protocol, right-click SNPP Providers and click Add.
Note: For you to use the WCTP protocol, the paging service must support Version 1.1 of the WCTP protocol.
A new item displays under either SNPP Providers or WCTP Providers, depending on which protocol type you have chosen.
The connection fields that are contained within this group appear according to the connection protocol selected for the current provider.
Note: The Paging Service Authentication button displays when you have added an item under the WCTP Provider section. If the application on the paging service provider's Web server (used to service WCTP Client page requests) requires user authentication, use this dialog to specify the user ID and password to be sent to this server application. For more information, see the HTML help for this dialog.
