After a GLV command executes, it sets the special REXX return code variable RC. The RC variable contains a value of 0 (zero) if the command executed successfully; otherwise, the RC variable contains one of these values:
RC |
Description |
-86 |
Unrecognized command name |
-84 |
Unrecognized command operand |
-82 |
Command operand is missing |
If the RC variable contains any other value, contact Technical Support at http://ca.com/support.
