Note: You need to perform the instructions in this chapter only if you specifically installed Open Object REXX on your machine.
Configuration Manager enables you to use the CA Automation Point address environment from Open Object REXX programs.
Use the REXX Settings dialog, to configure Open Object REXX.
Note: CA Automation Point supports only Open Object REXX version 4.0 or above.
