CA supplies several automation applications with CA Automation Point. The applications include:
The example applications may not provide the precise automation solutions appropriate for your site, but they show how all the parts of a working application are coded. Use them as a starting point for building more complex applications.
After installing the applications and performing a few site-specific customization tasks, they are ready to run.
Building block applications are prerequisites for running other CA-provided applications.
Each application provided with CA Automation Point has a corresponding .txt file that contains information about the application, such as:
You can find these sample files in the installDir\SAMPLE directory.
