Previous Topic: Search Order For REXX ProgramsNext Topic: Export and Import Operations
Managing Site Files
You can use the CA Automation Point Export and Import Utility to help you manage your site files and make backup copies regularly. It is important that you conduct ongoing backups of your CA Automation Point directory so that you can recover your configuration settings and notification policies in the event of hardware failure.
You can use the Export and Import Utility to do the following:
You can execute the Export and Import Utility from Configuration Manager or from the command line. Executing the utility from Configuration Manager is referred to as interactive mode. Executing the utility from the command line is referred to as unattended mode.
Note: Because the Export and Import Utility requires administrator rights, it is not generally possible to execute it from a rules file. If you try to run the utility from a rules file, the application can either fail (Windows Server 2003) or display a UAC interactive prompt (Windows Server 2008 and above). However, if the Automation Point Desktop is already running with administrator rights, the Export and Import Utility will inherit the required privileges, and the required operation can complete successfully.
