Configuring CA Automation Point › Managing Your Site Configuration
CA Automation Point supplies you with a rich set of extensions that you can use to configure and manage your site’s data to suit your needs.
- Use Configuration Manager to configure, view, and edit settings saved in user data files that customize your site. Configuration Manager saves the user data files in a directory structure separate from the directory where CA Automation Point-distributed files are installed.
- Use the Export and Import Utility to backup, export, or import the full set of Configuration Manager user data files and accompanying user supplied files residing in the Site directory. Configuration files exported from the local CA Automation Pointserver can be imported for use by a different CA Automation Point server. Likewise, configuration files exported from another CA Automation Point server can be imported for use by the local CA Automation Point server. Use the Export and Import Utility to facilitate upgrading the operating system or base hardware for a preconfigured CA Automation Point server.
- Use the Import Sessions Utility to import or export the user data files that define just your session definition sets. Importing and exporting session definition sets from one CA Automation Point server to another allows you to move session definitions without manually reconfiguring them.
